How to combine date and time columns?
I imported dataset with the separate date and time columns in text format. How can I create a new timestamp with them?
It will depend a little bit on the exact format of the strings.  First thing to appreciate is date/time is just the number of secs since midnight of 1/1/1904.  So we have to covert your date and time fields to seconds.
The date part can be handled with the date2secs(year, month, day ) so you may need to parse out your string accordingly.
For the time part this is Hours*60*60 + min*60 +secs
With the total added together.
The alternative is to double check your import settings and set the appropriate fields to Date/time and let IP do the conversion.
You probably can import them directly as date and time columns but it depends on the exact format of the file.
For background information, execute:
DisplayHelpTopic "Date/Time Waves"
DisplayHelpTopic "Loading Delimited Text Files"
To say more I would need a sample file.
In reply to by hrodstein
Thank you. I imported them as text because they won't show correctly at the time part with added 01/01/1904 (UTC?). Here is the screenshot of the date and time columns. Is there a direct way in Igor pro to combine them to a new "date-time" column as the excel does? I didn't do it in Excel because the dataset is too long to be read into Excel, but Igor has the capacity to read the data.
Screen Shot 2020-06-29 at 11.53.16.png (434.62 KB)
In reply to by hegedus
I have posted a snippet showing how to do this conversion.
It would be better to import the date as date/time. If you attach a sample file or sufficient subset of a file, I will see if that is possible.
