New Camera window and Object drawing
I am using the "Newcamera" feature and grabbing images into Igor. I wanted/needed to draw some ROIs on the live image. I tried different methods but I just couldn't do it. I even tried to embed the video as a sub window and stack it under another one so I could try to draw on in and finally overlap them, but unsuccessfully. Is there a way to do it?
The short answer is no. The camera window is not an Igor Graph window so you can't use the same tools. It is designed to allow you to display live images. If you want to interact with an image, select ROI or perform analysis you need to display a specific captured image in a Graph window. Note that if you capture images into a single fixed name wave, you can display that wave and it will update when the data in the wave is updated. Depending on your version of Igor there may be additional tweaks that you can use to improve performance. Feel free to contact support with more information about your application.
June 15, 2020 at 11:12 am - Permalink
It seems like you could also use "Modifycamera grabFunctionName=myFunc" with a user-defined function that does something like the following. This function receives the most recent frame as a wave -- perhaps at a lower frame rate than the camera window? -- and so that wave can be appended to graph, providing all the usual drawing and tracing methods for graphs.
June 15, 2020 at 11:30 am - Permalink
In reply to It seems like you could also… by gsb
I tried something similar by setting a background task and refreshing the wave content every 0.5s. Not a good idea. I am using the ModifyCamera now under user request. Not ideal, but it does the job.
Thank you all for the replies!
June 24, 2020 at 11:19 am - Permalink
In IP8 you can use SetIdlePeriod to affect the speed of updates. The background process is less than ideal for this application. Your own procedure should mark the wave as having changed and the shorter idle period should give you a more timely update.
June 24, 2020 at 03:52 pm - Permalink
