read in of a special text file format (ask before re-inventing the wheel)
stefanm
i try to read in a file like this
dist_1:BL_XAS
Datum;Zeit;Z[mm];I1;I2;I3;I4
27.05.2010;09:00:00;9.37;0.00;0.00;0.00;0.00
27.05.2010;09:00:10;9.30;0.00;0.00;0.00;0.00
27.05.2010;09:00:20;9.28;0.00;0.00;0.00;0.00
27.05.2010;09:00:30;9.18;0.00;0.00;0.00;0.00
27.05.2010;09:00:40;9.09;0.00;0.00;0.00;0.00
I don't need the first line, second line are the column name; first and second column gives date and time, which I want to merge in one column. The other columns are the output of a beam position monitor at my beamline. I would try to do this by "FReadLine". Does anyone has a better solution? Has somebody already some code, which is useful for the read-in of such type of files?
Best regards
Stefan
May 30, 2010 at 07:04 am - Permalink
