    Data-folder awareness for WaveList()
WaveList() is only returning results from the current data folder and thus needs acrobatics with SetDataFolder to work on different DFs. It is one of the few functions I use frequently which is not able to take a data-folder string or DFREF input. I propose the addition of this functionality (a new function WaveListDFR()?) to have this convenient function work with DFREFs.
I agree. This would help eliminate the gymnastics that one must sometimes undertake with SetDataFolder to jump around in data folders.
May 30, 2020 at 06:57 am - Permalink
Yes, it would be great to have that. In the meantime I use this:
May 31, 2020 at 02:08 am - Permalink
I think that new function should return a wave reference wave. And you have to ensure what you don't bug out, so something like
based on tony's solution.
June 1, 2020 at 04:44 am - Permalink
Thomas,
thank you for your suggestion and the code example. To be honest, I rather would get a string list as before from the function instead of a wave reference wave. I think a string list is easier to chop down further (e.g., by using GrepList()) than to handle wave references right away. Also, I wonder if in the code the ListToWaveRefWave(s) should come before the SetDataFolder command, otherwise the correct waves cannot be referenced, no?
June 1, 2020 at 08:47 pm - Permalink
@chozo. Thanks for the comment. Yes indeed the SetDataFolder must come later. And also handle an empty wave specially.
June 2, 2020 at 02:20 am - Permalink
To create a wave reference wave you can already do something like below, but sometimes it's useful to create a stringlist directly, for instance if you need it for a popup menu.
June 2, 2020 at 02:35 am - Permalink
Hi olelytken, great code example. I keep this in mind for later use.
June 5, 2020 at 05:34 am - Permalink
WaveRefIndexedDFR can be used to iterate through the waves in a particular data folder.
June 7, 2020 at 12:50 pm - Permalink
