Values from Empirical Distribution Functions
I have an empirical distribution of data, in this case intensity probability versus radius. I can get the values of the maximum radius (end point of the distribution) and most probable radius (radius at maximum intensity probability). I want to obtain values for the mean and rms radii (not the mean and rms of the intensity probability). Before I roll my own functions, am I missing an existing operation or function to get these values?
The analogy is to obtain various moments for the molar mass of a polymer from a distribution function of number of chains versus molar mass of the chain. It is equivalent to the question about radius of gyration in a distribution, which is the second moment of the distribution.
I can't think of an immediate built-in operation or function to compute these. In general, given pdf(x) you could compute any moment by integrating (in this case you seem to have finite limits [0,R]). You can compute the n'th moment using Integrate1D where your user function will return, e.g., (x^n)*pdf(x).
May 20, 2020 at 10:51 am - Permalink
Got it with a code snippet. Thanks.
May 20, 2020 at 12:49 pm - Permalink
