Deletepoints from 2D wave
vpratap397
I am looking for syntax to use deletepoints function to delete points from a 2D wave. The help on deletepoints doesn't have enough details.
Thanks in advance.
Thanks in advance.
Please tell us more. What exactly do you want to delete? Rows? Columns? Multiple? One?
To delete column 5 from a matrix:
DeletePoints/M=1 5, 1, matrixwave
To delete row 5:
DeletePoints/M=0 5, 1, matrixwave
Since the zero dimension (rows) is default, the second one doesn't need the /M=0 flag, but it doesn't hurt.
Replace "matrixwave" with the actual name of your matrix.
May 8, 2020 at 11:16 am - Permalink
I want to delete just one point or may be just a few. Don't want to delete whole row or a column.
thanks
May 8, 2020 at 11:19 am - Permalink
You can't do that to a matrix. If you delete one point from a row, what happens to the last column?
Or do you want to replace that element with something like Nan?
May 8, 2020 at 11:27 am - Permalink
I see your point. Then I guess I have to convert the 2D wave to 1D waves and then delete points separately in each wave.
May 8, 2020 at 11:32 am - Permalink
Yes, that would be what you have to do. And then it is permanently a 1D wave.
May 8, 2020 at 05:00 pm - Permalink
If you're using Igor 7 or later, you can use the SplitWave operation to easily split a multidimensional wave into multiple lower dimensional waves (in your case, 2D->1D).
May 11, 2020 at 05:09 am - Permalink
And I see now that you asked a different question about SplitWave, so I guess you already know about it :)
May 11, 2020 at 05:11 am - Permalink
In reply to And I see now that you asked… by aclight
Yes, I did. Thank you.
May 11, 2020 at 07:06 am - Permalink
