RE. setdatafolder
ychen344
I am playing with data folder reference with the following scripts and having trouble with the last commend "setdatafolder savedDF". The other one "setdatafolder path" worked fine. Reading the examples shown on Igor Manual V-761 did not give me an answer. Would appreciate your help. Thanks.
function datafolderreference () newdatafolder/O output DFREF savedDF=getdatafolderDFR DFREF path=savedDF:trial1 display path:stimWave setdatafolder path setdatafolder savedDF end
Think you need parenthesis with the getdatafolderDFR
DFREF saveDFR = GetDataFolderDFR()
otherwise you are setting saveDFR to a data folder called "getdatafolderDFR".
May 1, 2020 at 09:28 am - Permalink
Thank you!
May 1, 2020 at 04:17 pm - Permalink
