setAxis a multiple-wave graph
ychen344
Trouble with setAxis in a graph that has multiple waves when the waves have different x-axis scales.
For example, graphWindow contains 2 graphs: wave1_y vs wave1_x and wave2_y vs wave2_x. Wave1_x and Wave2_x have different scales. How to setAxis bottom for wave2?
Thanks
What you describe is two sets XY waves plated on a single set of axis probably 1 left and one bottom. They share the same axis.
So ideas to do things a bit differently.
1. You could scale one trace differently in the modify trace dialog.
or
2. When creating the graph initially you can set one of the traces to use a separate axis (either side or bottom).
Can you add a bit of description of what you would like to accomplish? I am guessing at the moment.
April 3, 2020 at 09:42 am - Permalink
