Quick and dirt tool for swapping Y axes.
polymerchm
I all too frequently add a trace to a graph with two different Y-axes and add it to the wrong one. Below is a procedure that adds a menu to the right-click popup to swap the axes. After right-clicking a trace, click the bottom menu item. The initial stuff is "borrowed" from the manual. Put it in your local user procedures folder.
#pragma TextEncoding = "UTF-8" #pragma rtGlobals=3 // Use modern global access method and strict wave access. Menu "TracePopup", dynamic TraceClickerPosition(), /Q, TraceClicker() end function /s TraceClickerPosition() getmouse /W=kwTopWin variable /G V_TraceMenuX=V_left return "Swap left and right Y axis" end function TraceClicker() // figure out graph and trace names GetLastUserMenuInfo // figure out mouse position within graph on SECOND click getmouse /W=$S_graphName string s_info=traceinfo(S_graphName, S_traceName, 0) string s_xwave=stringbykey("XWAVE",s_info) string s_yaxis=stringbykey("YAXIS",s_info) RemoveFromGraph $S_tracename if (CmpStr(s_yaxis, "left")==0) // delete this curve and re-add it on the right AppendToGraph/R $s_tracename vs $s_xwave else // delete this curve and re-add it on the left AppendToGraph/L $s_tracename vs $s_xwave endif return 1 end
FWIW, Igor 8 and later already have this feature built-in--right click on a trace and select "Move to Opposite Axis".
March 2, 2020 at 07:12 pm - Permalink
Still in the dark ages of Igor 7. ;-)
March 3, 2020 at 04:06 pm - Permalink
