indexing from the end in a list
Can I index an item from the end of a list?
If I have a list {A, B, C, D},
can I use -2 to specify C?
No, sorry.
It is also good to note that Igor's compiler knows nothing about optimization, so if you are going to access list items at the end repeatedly, it is better to store the list length in a variable. So this:
Variable nitems = ItemsInList(theList)
Variable i
for (some sort of loop)
    String oneitem = StringFromList(nitems-2, theList)
is to be preferred over this:
Variable i
    String oneitem = StringFromList(ItemsInList(theList)-2, theList)
The second version will repeatedly walk through the entire list counting the items, the walking through the  list looking for requested item. The first version still has to walk through the list looking for the requested item, but doesn't have to count the items again.
But be careful about removing items from the list! In that case, storing nitems can lead to bugs!
I should also note that in some cases it may be more efficient to put your list items in a text wave. Those items can be found without walking through the list.
