Can axes be plotted above traces?
ilomdez
I was wondering if there is any way to make axes appear above traces (by default they appear below).
I would like to do so because when plotting certain figures, such as contour plots (see example attached), the traces are visible lying above the axes. I guess that the standoff feature was indeed intended for this purpose but, sometimes, a tight frame just looks better.
![Contour plot where the traces are visible lying above the axes](/sites/default/files/styles/content_body/public/2020-02/ContourExample.png?itok=NBlKeulQ)
In the modify axis dialog, select "Draw on top of traces" for each axis.
From the command line: ModifyGraph axisOnTop=1
February 18, 2020 at 02:55 am - Permalink
In reply to In the modify axis dialog,… by tony
I can't believe I haven't found that... sorry for bothering
Thanks Tony!
February 18, 2020 at 02:57 am - Permalink
