Help needed for trouble shooting "XOP is incompatible with this version of Igor"
I am trying to migrate from Igor 6 to Igor 8, and I need to recompile some XOPs to do that.
The XOP was written for 32-bit hardware in Igor 6, now it will be used in Igor 8 (32-bit).
According to the manual, I should first update it using XOPToolkit7, then XOPToolkit8.
I did it by first copying the XOP folder (A) to XOPToolkit7 folder, then use the exp file "Create New XOP Project" to copy (A) to (B). Here I used Igor 8 to open this experiment file.
Then, I compile the file normally. Afterwards, I copy the folder (B) to XOPToolkit8. Using the experiment file of the same name "Create New XOP Project", I created a copied (B) to (C). Then I compiled (C) normally.
However, on trying, the XOP I obtained in folder (C) shows the same error in title.
Any help will be appreciated.
Check your XOPMain function. It may be doing a test on the Igor version and returning XOP_OBSOLETE.
Check your XOPI 1100 resource. See "The XOPI 1100 Resource" in Chapter 4 of the XOP Toolkit 8 manual.
If that does not solve the problem, clean your project*, zip it, and send it to WaveMetrics support.
* A cleaned VC project should have no build or only these files in the VC folder:
<XOPName>.sln
<XOPName>.vcxproj
<XOPName>.vcxproj.filters
It should not have these files and folders which you may need to manually remove:
.vs
Debug
x64
*.bsc
*.ilk
*.pdb
*.VC.db
NOTE: Be careful not to delete the .sln, .vcxproj, .vcxproj.filters files or any files that you may have put in the VC folder.
In reply to by hrodstein
<XOPName>.sln
<XOPName>.vcxproj
.vs
Debug
x64
*.bsc
*.ilk
*.pdb
*.VC.db
This seems to be the culprit, by commenting that section out it compiles and could be loaded by Igor. I will test it later to see if it does work.
Thanks for the help.
