passing on optional parameters
harneit
I would like to be able to say something like
function foo(a,[b])
variable a, b
return a+bar([b]) // or, possibly, bar(b=b)
function bar([b])
variable b
if( ParamIsDefault(b) )
b=2
return b+1
variable a, b
function bar([b])
variable b
b=2
return b+1
but it seems that I have to use instead
function foo(a,[b])
variable a, b
return a+bar(b=2)
return a+bar(b=b)
function bar([b])
variable b
b=2
return b+1
variable a, b
return a+bar(b=2)
return a+bar(b=b)
function bar([b])
variable b
b=2
return b+1
I thus have to call
ParamIsDefault()
twice although function foo()
does not really care about parameter b
. More importantly,
foo()
has to know the default value for b
, which could be computationally costly in a real-world example.(Note: incidentally, calling
bar(b=b)
when b
is actually default (as indicated by the comment in the first example) does not throw an error since a missing variable is automatically initalized to zero; in the contrived example above it would only give the "wrong" result foo(1)=2
instead of foo(1)=4
--- with optional string parameters, the syntax does throw an error)Any suggestions?
ParamIsDefault
twice since both of your functions do care about b (i.e. they have different behavior depending on whether the optional parameter is set). You can rewrite much more concisely with the trinary conditional operator , though. This is an idiom I use all the time:variable a,b
b = paramIsDefault(b) ? 2 : b
return(a + bar(b=b))
function bar([b])
variable b
return(b+1)
May 2, 2010 at 06:22 am - Permalink
variable a, b
return a+bar()
return a+bar(b=b)
function bar([b])
variable b
b=2
return b+1
Jeff
May 4, 2010 at 10:47 am - Permalink
That is a cool way to collapse the ParamIsDefault syntax!
This still has the downfall that foo must know in advance the default value of b in bar. That requirement could be rather difficult to keep in larger or more complex programming code.
For this reason, I can see why the ability for foo to pass its (otherwise empty) default parameter b on to bar to be recognized as such and without throwing an error would be useful.
May 4, 2010 at 04:40 pm - Permalink
You can do this too. I typically pass nan as a parameter for this purpose:
variable a,b
b = paramIsDefault(b) ? nan : b // NOTE CHANGE HERE
function bar([b])
variable b
b = paramIsDefault(b) || numtype(b) ? 2 : b // NOTE CHANGE HERE
return(b+1)
May 6, 2010 at 10:36 am - Permalink
I do this as well, and you can do the same thing with optional string parameters, passing them as empty strings. Since Igor 6.12 or so, you have been able to have lines like this:
assuming b is a string variable.
May 7, 2010 at 09:51 am - Permalink
