Bug in Modify Graph Dialog
endyaust
I'm using "perunit" scanning on a graph in Igor 8.04 (on a Mac running Mac OS 10.14.6) and have found that the "perunit" option for graph scaling is being rounded to two significant digits by the dialog box. This makes it impossible to properly scale graphs.
There is an easy workaround of using the command line operation but it would be good if this bug could be fixed.
Regards,
Bruce
I think this was a mistake introduced when porting the Modify Graph dialog for Igor 7.
I have fixed this for per Unit and Absolute scaling. This will be available in tomorrow's nightly build. Use the Help->Igor Pro Nightly Build menu item to get the nightly build.
January 15, 2020 at 01:31 pm - Permalink
