Igor 8 Shortcut to Graph Browser
IgorPal
Hi guys,
I'm usually dealing with a great amount of graphs in Igor and therefor I'm using the Graph Browser excessively...
Is there a shortcut for the graph browser that I'm not aware of? Is there a way to set one?
It would makes things so much more handy, just as the CMD+J and CMD+B commands save you much time when you're manually playing with waves in the command window...
Best
December 11, 2019 at 03:04 am - Permalink
Igor 8 comes with a new built-in Window Browser, which includes most of the functionality of the procedure based Graph Browser as well as a lot of other functionality. You can use tony's suggestion to create a shortcut key for the browser, or you can also use the tool bar button on Igor's main toolbar (also new in Igor 8). Use the Windows->Show Toolbar menu item if you don't see the toolbar.
December 11, 2019 at 08:04 am - Permalink
thanks for the tip tony.
when working on a laptop it's often convenient to avoid mouse usage.
March 19, 2020 at 08:33 am - Permalink
Or you could edit your Igor Pro 8.ini file to have this:
You can get the MenuAndItemNames list from the SetIgorMenuMode.ipf file (see the WMProcedures Index help file).
March 19, 2020 at 10:36 am - Permalink
