Some "Straightforward" Gizmo applications
Hello There igorpro,
I am trying to do some pretty basic stuff with the Gizmoplot, that apparently, is way too complicated for me:
I have started with a parametric plot using 3(x,y,z) matrices. (see fig1)
Using the gizmo panel, i managed to make 2 custom axes offset appropriately(so that the data would not hide them)
-I rotated the tick values so that you could see them, and they wouldn't be backwards (backwards text seems to be the default when viewing a gizmo plot from above. Very strange)
It now looks like Fig2.
I haven't tried, but i have a recreation macro for all of this, and I assume I can use the procedure window to scrape all of the commands to use for a later program to make, and set these specific axes.
-The one, most annoying thing, is that the axis label for a custom axis will absolutely not display, no matter what I try.
- The one success I have had with getting the custom axis label to display was to create an axis triplet, and then label that, Then reduce it to a custom axis in the dimension that I want. This preserved the label, but while messing with tick marks and offsets, the label disappeared and will not reappear, even when using:
ModifyGizmo ModifyObject=axes1, property={-1,axislabel,1} command (yes, axes1 is the correct custom axis, yes I re-entered the label text)
Is there a secret menu-item that will make a label actually show up?
Please do not refer me to the Showhelp Gizmo Reference. I have looked through it and the lack of context within the whole thing was pretty unhelpful
I am using igorpro 6.37
Thank you in advance
-Cory
Hello Dolbash,
You appear to be using an old version of Igor that is no longer supported.
I do not understand what you are trying to accomplish. Your best bet is to post an experiment (not an image) and explain your requirements in detail.
AG
November 27, 2019 at 07:18 am - Permalink
