Saved on XXX at yy:zz no longer in the command window ?
millot1
Before Igor 8, saving the experiment resulted in a statement in the history such as
***Saved on Fri, Oct 31, 2014 at 10:29:54 AM to file, Macintosh HD:Users:...
Is there a way to reactivate for Igor8?
That statement likely came from a procedure file you or another person wrote and put into your Igor Procedures folder.
Look for the file in your Igor 6 Folder's Igor Procedures folder. It may be in your ~Documents/WaveMetrics/Igor Pro 6 User Files/Igor Procedures folder.
The file likely contains a Function BeforeExperimentSaveHook(....
November 13, 2019 at 03:31 pm - Permalink
Strange... because I cannot find anything like such a function in Igor6 files
But thanks for your reply I adapted the standard one for Igor8 as
Variable rN,kind
String fileName,path,type,creator
PathInfo $path // puts path value into (local) S_path
Print "******* Saved on ",date(), " at ", time()," into ",S_path+fileName, "\r"
KillPath/A/Z // Delete all unneeded symbolic paths
November 14, 2019 at 06:12 pm - Permalink
Variable rN,kind
