Does Debugger affect execution time?
s.r.chinn
Does enabling the Debugger in all procedures used in executing a function slow the execution speed? I could find no mention of this in the IP8 User Manual. My code takes several minutes to execute, so even small increments of speed would be useful, e.g. by disabling the Debugger.
You can find out for yourself by using some of the built-in timing functions. For example, you can StartMsTimer before running the code and then StopMsTimer after it is completed, or record Ticks before and after the function runs. I would time your code with the debugger enabled and disabled, and see if there is a reliable difference.
For more comprehensive analysis, see DisplayHelpTopic "Profiling Igor Procedures" (though the more basic functions might be more straightforward since what you're concerned about--the built-in error handling--might get used to some extent by the Profiling code.)
October 15, 2019 at 08:39 am - Permalink
You can use DebuggerOptions to programmatically turn the debugger on/off and then benchmark.
October 16, 2019 at 12:15 am - Permalink
Thanks for the responses. I had already incorporated Profiling and internal timing, but (being lazy) was hoping for a quick response based on someone's prior experience. In case others might be interested, using Thomas' suggestion I got the following results:
Profiling Debugger Time (sec, in largest code loop)
ON ON 614.6
ON OFF 608.0
OFF ON 592.8
OFF OFF 568.0
The lesson I draw is that profiling is useful for improving code, but should be applied sparingly otherwise.With no profiling, the Debugger does seem to add a small, but significant execution time increase. All times usually have a few second variation from trial to trial. (results with IP 8.03, Win10)
October 16, 2019 at 03:30 am - Permalink
Thanks for the numbers. Is the code short enough to be posted here? Maybe we can still optimize it ;)?
October 16, 2019 at 11:35 am - Permalink
Thomas, unfortunately I am not permitted to post the code (it is also large, and somewhat disorganized). I have performed extensive profiling, and A.G. has been of great assistance in applying MatrixOP to implicit-index wave assignments, and relocating factorable loop variables in the "high-value" Profile targets. The code structure is essentially sequential, so MultiThreading has not proved useful.
October 16, 2019 at 12:07 pm - Permalink
