Specificity of selection for submenus with PopupContextualMenu
I have run into some behavior that I don't know how to resolve (Igor 8, Mac).  I have an interface that uses PopupContextualMenu, and the menu has a submenu of a list of waves.  I want to add a second submenu that offers a different operation but on the same list of waves.  The problem is that v_value and s_selection seem to return values referring to their individual submenus, and do not report which item in the parent menu was selected.
I've written a simplified example to illustrate the basic problem:
menu "Tester", contextualmenu
    submenu "action 1"
        "wave1"
        "wave2"
    submenu "action 2"
        "wave1"
        "wave2"
function testMenu ()
    PopupContextualMenu /N "Tester"
    print v_kind, v_flag, s_selection
If you enter "testmenu ()" on the command line, it will give you the popup menu.  If you select action1->wave1, you get the same v_kind, v_flag, and s_selection as if you had selected action2->wave1.  So, how can I distinguish the two?  Any suggestions for a work-around?  Is renaming the items in my submenus the best choice?   I am grateful for suggestions.
-Matthew
    submenu "action 1"
        "wave1", SaveMenu("action 1")
        "wave2", SaveMenu("action 1")
    submenu "action 2"
        "wave1", SaveMenu("action 2")
        "wave2", SaveMenu("action 2")
    SVAR strMenu
    print v_kind, v_flag, s_selection, strMenu
function SaveMenu(strSubmenu)
    string strSubmenu
    string /G strMenu=strSubmenu
Here's a workaround similar to Tony's, but it doesn't require a global variable
    submenu "action 1"
        "wave1",menuAction("action 1")
        "wave2",menuAction("action 1")
    submenu "action 2"
        "wave1",menuAction("action 2")
        "wave2",menuAction("action 2")
function menuAction (menuName)
    String menuName
    getlastUserMenuInfo
    print "selection index=",v_value,"wave name=",s_value,"menuName=",menuName
Actually, you don't even need the extra function if you take the global route:
    submenu "action 1"
        "wave1", string /G strMenu="action 1"
        "wave2", string /G strMenu="action 1"
    submenu "action 2"
        "wave1", string /G strMenu="action 2"
        "wave2", string /G strMenu="action 2"
function testMenu()
    SVAR strMenu
    killStrings/Z strMenu
The advantage of using global string is that you don't transfer execution to a different, isolated function. The disadvantage is that it uses a global string.
That's a nice trick.  I was a bit worried if it would work for my actual problem.  The submenus are dynamic, lists of waves returned by a string function.  I think that function calls can't be attached to individual menu items specified using semicolon-delimited strings ("item1;item2").  However, I can put the function call after the dynamic call.  So, the below is a better representation of my situation, and your solutions will work.  So, thanks again!
-Matthew
menu "Tester", contextualmenu, dynamic
    submenu "action 1"
        listitems(), string /g strmenu="action1"
    submenu "action 2"
        listitems(), string /g strmenu="action2"
function /t listitems ()
    string returnstr
    returnstr = "item1;item2"
    return (returnstr)
    SVAR strmenu
    print v_kind, v_flag, s_selection, strmenu
