function/wave and return
I wonder if there is a recommended procedure for the following case:
function main()
    wave w = sub()
    return sum(w)
function/wave sub()
    wave/Z WaveMayNotExist
    if(!WaveExists(WaveMayNotExist))
        // this may also be another condition that causes the function to not run through
        // what's best to return now? A non-existing wave? Make/N=1 w=NaN; return w?
        return NaN
    Make/N=(numpnts(WaveMayNotExist)) output
    // more code
    return output
 Obviously "return NaN" is inconsistent with the function type although it compiles but gives an unexpected result (at least for me):
print main()
  0
I would recommend to return
this is an invalid wave reference. The code then bugs out at
Wave w = sub()
which is what you expect or?
In reply to by johnweeks
johnweeks wrote:
Wave w = sub()
if (WaveExists(w))
    ... do something ...
John, yes, main() should contain something like this but I was just puzzled what to return from sub() in case it aborts.
this is an invalid wave reference. ...
 Thanks Thomas! That works for me and is what I was looking for!
Cheers
Christian
If the wave may not exist, you should use /Z, like this:
Wave/Z w = sub()    // Use /Z here
if (WaveExists(w))
Without the /Z, if you are running with debugging enabled and "NVAR SVAR WAVE Checking" turned on, which is recommended during development, Igor will break into the debugger to let you know you are using a NULL wave reference.
With /Z, Igor will not break into the debugger, because /Z tells Igor "I know that this wave reference may be NULL".
For details, execute:
and especially the section "Runtime Lookup Failure".
