Help! How do I do a BOX PLOT??
LaMP
I am trying to make a box plot for my data and although I have looked at the demos I just don't manage.
I have a data series Y that I want to represent against X (attached databoxplotinputXY).
I would like to bin X in 0.1 size bins (from 0 to 1) and represent the Y data (as a box and whisker plot) as a function of each of these size bins. See attached graph (averaged_dataXY).
Thanking you all in advance
Here is How I created the graph.
1. Create a text wave with the labels 0-0.9 in 0.1 increments.
I then created a box plot using the now split waves (10 of them) and with GroupLabel as the label wave.
August 26, 2019 at 02:45 pm - Permalink
Hello Andy,
Thank you for getting back to me so quickly. So the final boxplot that you showed is EXACTLY what I want to do, however the problem I am having is going trom the step where the data is split over the different bins to generating the boxplot.
When I use the boxplot function, it only creates the data with one point.
?? Can you explain how you plotted the binned data as a box/whisker. ??
Thanks again.
August 26, 2019 at 03:04 pm - Permalink
I am using IP 8 and there is a built in box plot functionality. In the dialog box you select the waves which represent each box and the labels.
August 26, 2019 at 03:13 pm - Permalink
Ah OK. I am in IP 6!! Is there something similar that can be used?
Thanks
August 26, 2019 at 03:18 pm - Permalink
"IP6 - now that is a name I have not heard in long time"
A couple of steps.
first in the procedure window add:
#include <Percentile and Box Plot>
Then I rename Grouplabel to some thing that does not with "G" - you will see why in a moment.
Then under window select Box Plot.
I then select waves by name and Use "G*" to select the split waves -this is why I needed to rename.
Select replicates are "columns" which indicates that each wave is a single group.
And the X label is the renamed wave.
If you need to add the data points, that is a bit more complex.
August 26, 2019 at 04:00 pm - Permalink
Yes we have some software that was only compatible (until recently) with 6!! We should be moving on soon :)
I just want to thank you for your help. I managed to do the BOX plots in time!! I can try modifying them by adding the data points or having several BOXPLOT in the same plot.. but it is less urgent!!
August 27, 2019 at 02:21 pm - Permalink
Happy to help.
August 27, 2019 at 02:28 pm - Permalink
