Q1: How to delete a column from a 2D wave? Q2: Can I print "on" a panel?
Peeyush Khare
Q1: I have a 2D wave: raw[14150] [851]. I want to get rid of the first column: raw[p][0] of the wave so the new wave becomes raw[14150][850]. I have a feeling it's a pretty simple command but unfortunately I haven't been able to figure this out. Kindly advise. Thanks!
Q2: I have a built a panel which performs a variety of operations via clicking buttons. What I want to do next is to execute a print command such that when a button is clicked to load a file, a sentence prints "on" the panel (i.e. in a clear space on the panel's surface) saying "file xyz is loaded". But I have no idea how to do this. Please help. Thanks!
For Q1: if raw is 14150 rows and 851 columns,
August 13, 2019 at 02:08 pm - Permalink
To delete a column, you can use the deletepoints command with the/m flag to designate the dimension, 1 for columns in your case. For example if you wave is "Fred"
deletepoints /m=1 0,1,Fred would delete the first column of Fred.
To your second question: I would create a title Box and either reference a string variable. To hide the box just set the string variable to "". Later when you want to show a message, just change the value of the string variable.
August 13, 2019 at 02:14 pm - Permalink
In reply to For Q1: if raw is 14150 rows… by sjr51
Thanks sjr51! very much appreciated.
August 14, 2019 at 08:17 am - Permalink
In reply to Hi, To delete a column, you… by hegedus
Hi Andy,
Thanks a lot! It worked!
Peeyush
August 14, 2019 at 08:19 am - Permalink
Q1: The simple way in IP8:
MatrixOP/O newWave=subRange(raw,0,14149,1,850)
Also, since you are only removing one column you can also use Duplicate/R=[0,14149][1,850] raw,newWave
Q2. There are different ways to print text on a panel. The first decision you need to make is if you want to keep all the information and be able to scroll through it. If so, I recommend embedding a notebook in the panel and adding text to it as you go. This is pretty simple as in, e.g.,:
NewNotebook /F=1 /N=notebookName /W=(57,277,748,500) /HOST=Panel0
Look for the notebook command for adding text.
If you do not want to keep all the information you can use a SetVariable control that is set to some internal text. For example:
To execute the "printing" you will overwrite the content of the control:
SetVariable setvar0 win=panel0,value= _STR:"This is New Text"
I hope this helps,
AG
August 14, 2019 at 05:53 pm - Permalink
