Create a folder using a variable name
Hello everyone,
Beginner here, I used Igor for a little while now but only using user-built macro (not by me), and I would like to start doing things by myself.
I have a lot of waves, and for each of them I need to copy them and make various operations on the different copies. This seems a easy enough task to begin with.
My issue is that I would like to create a new folder for each of those waves, names after the wave, in which all the copies would be stored.
Basically, if I have "wave1" in root, I want my function to make a subfolder called "wave1", and then copy "wave1" in it.
The issue in the following example of what I tried the new folder created is literally called WaveName, and not the name of the wave I put in the function when running it.
Any advice ? I feel I am still a bit confused by what is recognized as what in Igor.
function PrepWave(WaveName) String WaveName Wave W=$WaveName NewDataFolder/o/s WaveName Duplicate/o W, root:WaveName:W_1 End
NewDataFolder expects a name.
Your WaveName parameter is a string. Use $ to convert the contents of string into a name.
For details, execute:
Also, I recommend that you change the name of your parameter from "WaveName" to something else, such as "Name", because WaveName is the name of a built-in function which can cause confusion.
You have a similar issue with your Duplicate statement. You can fix it using $.
July 13, 2019 at 10:42 pm - Permalink
In reply to NewDataFolder expects a name… by hrodstein
Thank you, it worked.
I had already tried using $, but a error was returned, I assume it was because of the use of "WaveName".
Here is the MWE I have now.
July 14, 2019 at 05:02 am - Permalink
