inverse laplace transform
clarkac
Is there no interest, or simply no way forward?
Are there any igor tools for NMR analysis available? (the following has apparently expired: https://www.wavemetrics.com/users/tools_NMR.htm )
Tony
I note that the package includes both procedures and XOPs that were written when Igor 3.0 was the current version.
The Macintosh XOPs run only on a Power PC machine; most modern (Intel) Macs will not run them unless "Rosetta" is installed, typically earlier than OS X 10.5, though old machines upgraded from 10.4 to 10.6 would possibly still have Rosetta installed.
The Windows XOPs might run successfully on a 32-bit version of Igor, say Igor 6.3.7.2, but I haven't tested them.
January 31, 2017 at 05:47 pm - Permalink
In reply to by JimProuty
Thanks Jim. I'll try it out and see if it works in Igor PRO 8 for Inverse Laplace Transform of NMR signals.
June 28, 2019 at 01:03 pm - Permalink
