Extracting columns from 2D Histogram
I have built a 2D histogram, and I would like to create a function that essentially does the following:
From row 1 to 2, sum the values for every individual column. Histogram the summed values into a 1D histogram.
I understand the following snippet sums all columns in the matrix, but I'm not sure how to add the condition of a row range.
MatrixOP 1DHist=sumCols(2DWave)
I have attached a picture of the 2D histogram matrix. For example, for rows 1 to 2, column 1 sums to 0, column 2 sums to -1, and column 3 sums to -1. I want to store these values in a single wave and histogram them into a 1D Histogram
Thanks in advance.
There are a few different ways to do this. One way is to use the Duplicate command with the /RMD flag first and then run the MatrixOp on that. In your case:
If you want to do this as a function, you can specify the first and last row as variables using arguments in your function call. Plus, add the /FREE flag to the duplicate command to only temporarily store the tempMatrix.
May 24, 2019 at 12:32 pm - Permalink
There is no need to explicitly duplicate the desired range since you can execute the equivalent inside the matrixop command:
MatrixOP/O aa=sumCols(subRange(the2DWave,1,2,0,numCols(the2DWave)-1))
... and you may want to transpose the result (add ^t at the end) so it is a simple 1D wave.
May 24, 2019 at 04:23 pm - Permalink
