Please advise: Curve-fitting based on the equation obtained by numeric integration
smdl
My situaion is little complex.
I have a equation as a function of x for curve-fitting.
The problem is that I have to get the equation by numerical integration with respect to y, another variable:
My fitting (x) = Integrate from y=0 to y=Pi; cos(x-y)*exp(cos(y))*dy
I think that the Igor cannot do symbolic integration in my case but there should be a way to get the solution.
Could you please help me out how to solve this problem?
Thanks in advance.
Jongill
If you run into troubles, you can contact support@wavemetrics.com.
April 4, 2008 at 03:58 pm - Permalink
I really appreiate your quick answer for my post.
Unfortunately, I was so stupid that I realized that I did not ask what I intended to ask. You IntegratedID can certainly solve my problem on the Forum.
Please give me an additional advice on the following problem if you have time. I again really appreciate your valuable time and kindness.
The problem I have is that my fitting parameter w_coef[0] should be located in my "user-defind function1" for the first integration wrt a y variable. When I recall the "user-defind function1," in my curve-fitting function with a variable x, the fitting does not work with the w_coef[0] and w_coef[1]. I defined w_coef[0] as a golbal variable, which seems to be the problem maker.
How can I recall the w_coef[0] in my fitting function for curve-fitting? Please see below the igor procedure that I used, which does not work :-)
Could you please let me know the way to solve this problem?
Thanks again.
Best,
Jongill
Function/D UserDefinedFunction1(yy)
Variable/D yy
Variable/D kk = 1 // constant (actually another fitting coefficient)
NVAR globalX=globalX
NVAR globalW=globalW
return cos(globalX-yy)*(exp(kk*cos(yy-globalW))/2*pi*bessI(0,kk))
Function/D MyFtting(w, x)
Wave/D w
Variable/D x
globalX = x
globalW=w[0]
return w[1]*integrate1D(UserDefinedFunction1, 0, 2*pi, 0)
April 5, 2008 at 07:22 pm - Permalink
>How can I recall the w_coef[0] in my fitting function for curve-fitting? I
>am attaching the igor procedure and the the experiment that I used, which
>does not work :-)
NVAR doesn't create a global variable, it just looks up a pre-existing global variable and makes a local reference to it. One way to make this work would be to change MyFitting() to use Variable/G:
Wave/D w
Variable/D x
Variable/G globalX=globalX
globalX = x
Variable/G globalW=globalW
globalW=w[0]
This way, MyFitting() will create the global variables if they don't exist already. Then the NVAR statements in UserDefinedFunction1() will connect with those variables.
Another way to handle this is to have a third function that runs before you start the fit. This function would create any needed global variable or waves. Then the NVAR statements in UserDefinedFunction1() and MyFtting() would work.
April 7, 2008 at 05:10 pm - Permalink
