Pause in 'for' loop with opportunity to work with other windows
Physicist92
Hi all,
Is there possibility to make a pause in 'for' loop with the opportunity to work with other windows within Igor Pro? I tried to use DoAlert, but this command doesn't allow to perform actions in other windows. For example, I have a data set of 20 experimental graphs. I use loop for(i=0; i<numItems; i+=1). First, i = 0, display graph, then pause to allow me to perform manual fitting in selected range using specified panel with a number of buttons. Second, i = 1, display graph, then pause to do fitting, and so on. How can I implement it?
Here is the main function:
Function Fit_Semilog() DoWindow/F FittingPanel if (V_Flag != 0) return 0 endif NewPanel /N=FittingPanel /K=1 /W=(316,379,680,700) as "Fitting Panel" Button FitInFullRange,pos={30.00,20.00},size={300.00,20.00},proc=FitInFullRangeProc,title="Fit in full range" Button Show_Info,pos={30.00,50.00},size={300.00,20.00},proc=Show_InfoProc,title="Show Info" Button Hide_Info,pos={30.00,80.00},size={300.00,20.00},proc=Hide_InfoProc,title="Hide Info" Button FitInSelectedRange,pos={30.00,110.00},size={300.00,20.00},proc=FitInSelectedRangeProc,title="Fit in selected range" Button SubtractFitValFromFirstPart,pos={30.00,140.00},size={300.00,20.00},proc=SubtractFitValFromFirstPartProc,title="SubtractFitValFromFirstPart" Button RemoveFitFromGraph,pos={30.00,170.00},size={300.00,20.00},proc=RemoveFitFromGraphProc,title="Remove fit from Graph" Button TryAgain,pos={30.00,200.00},size={300.00,20.00},proc=TryAgainProc,title="Try again" Button SaveGraph,pos={30.00,230.00},size={300.00,20.00},proc=SaveGraphProc,title="Save Graph" Button Continue_,pos={30.00,260.00},size={300.00,20.00},proc=Continue_Proc,title="Continue" String listX = WaveList("*Time",";","") String listY = WaveList("*Int",";","") Variable numItems = ItemsInList(listY) Variable i String nameY, nameX for (i=0; i<numItems; i+=1) nameX = StringFromList(i,listX) nameY = StringFromList(i,listY) Wave wX = $nameX Wave wY = $nameY Display wY vs wX ModifyGraph mode=3,marker=19,msize=1,rgb=(0,0,65535) Display wY vs wX ModifyGraph mode=3,marker=19,msize=1,rgb=(0,0,65535) Display wY vs wX ModifyGraph mode=3,marker=19,msize=1,rgb=(0,0,65535) // Here should be a pause with opportunity to work with other windows endfor End macro FitSemilog() Fit_semilog() end
DisplayHelpTopic "pause for user"
May 13, 2019 at 04:17 am - Permalink
In reply to DisplayHelpTopic "pause for… by tony
Thank you!
May 13, 2019 at 09:16 am - Permalink
