Add date to time wave
I have collected temperature data with a time stamp that only gives HH:MM:SS, so running the experiment overnight causes the data to loop at 11:59:59. I would like to append dates (4/16/2019 and 4/17/2019) to the appropriate range of points in the wave so that I end up with: month/date/year HH:MM:SS. Any help is much appreciated. Thank you!
-Kevin
Igor stores date/time values as the number of seconds since 1904-01-01.
You can get this number for a given date using the Date2Secs function.
If, for example, your wave consisted of time-of-day (in seconds since midnight) for 2019-04-16, you could add the date part to the time part like this:
Variable startDt = Date2Secs(2019,04,16)
wave0 += startDt  // Add date to time-of day
Before you do that, make sure that the wave is double precision and has data units "dat". Execute this for details:
DisplayHelpTopic "Date/Time Waves"
hrodstein's solution will make every repeated day range have the same date. Here is a function that will take your cycled time-of-day data and add the appropriate date to each day:
Function RolloverPatcher(wave timeWave, Variable year, Variable month, Variable day)
    Duplicate/FREE timeWave, difwave
    difwave[0] = 0
    difwave[1,] = timeWave[p] < timeWave[p-1] ? difwave[p-1]+1 : difwave[p-1]
    Variable datesecs = date2secs(year, month, day)
    timeWave += timeWave + datesecs + 86400*difwave
Here's a slightly more efficient version:
    Duplicate/FREE timeWave, datewave
    datewave[0] = date2secs(year, month, day)
    datewave[1,] = timeWave[p] < timeWave[p-1] ? datewave[p-1]+86400 : datewave[p-1]
    timeWave += datewave
