deleting 2 end points
Amo
Hi forum,
How to delete two end points of a wave for any wave size?
I know I can use
DeletePoints 136,1, My_wave1
DeletePoints 0,1, My_wave1
in this case My_wave1 has 136 points and yes this way I can delete two end points , but since i will add this to my procedure, I am loading waves with say 150, 120 points or other sizes. what do you suggest ?
Thank you,
For arbitrary 1D waves you could use the following:
Redimension/n=(DimSize(waveName,0)-2) waveName
You could use a similar approach with DeletePoints.
March 26, 2019 at 12:33 pm - Permalink
That removes the last two points which is I take to be different than the request. I am reading it as remove the first and last point.
Given that, perhaps something along these lines. Note order of deletion do the last point first since deleting the first point shrinks the length of the wave and you will get an out of index error.
wave WaveIn
Variable EndOfWave
EndOfWave = numpnts(WaveIn)-1 //remember 0 based indexing so last index point is length -1
DeletePoints EndOfWave,1, WaveIn
DeletePoints 0,1,WaveIn
March 26, 2019 at 12:59 pm - Permalink
Sorry if I misunderstood the OP. If indeed first and last are to be eliminated (1D wave) then using IP8:
MatrixOP/o waveName=subRange(waveName,1,numRows(waveName)-2,0,0)
March 26, 2019 at 01:05 pm - Permalink
In reply to Hi, That removes the last… by hegedus
Thank you very much ,
March 27, 2019 at 06:18 am - Permalink
