Gizmo plane projection
I'm new to the Gizmo function, so I'm asking what may be a simple question: I have a 3D scatter plot in "box"-type axes, and I would like to project the scatter data onto one or more of the box faces.  Is there a simple way to do this? I figure I could make a standard 2D scatter plot, save it as an RGB image, then append that image into my Gizmo plot, but I'm hoping there's a simpler way so that if I add data to my 3-column array it automatically updates the 3D scatter plot and the projections.
Try this to see if it does what you want:
In the Gizmo Info panel, double click on the Scatter object in the Object list.
In the resulting Scatter Properties window, select the Drop Lines tab. This will give you a variety of options for creating drop lines to various projection surfaces.
In reply to by s.r.chinn
That's close, but I'm looking have the projection down to the planes without the drop lines.  Ideally it would look akin to a shadow of the scatter plot against the planes, where the size of the scatter points is retained.
Actually, based on a previous post about something similar, I realized the simplest way to do this is to duplicate my triplet wave, and flatten one dimension to a constant value at the location of the plane I'm interested in.  Then it can just be added as a scatter plot with the same size and color settings as the non-flattened wave.  In my case, I wanted to project the data onto the XY plane, so I duplicated the triplet wave and set the z wave to the minimum of the z-axis.  The point size in my case had its own wave, which I also flattened for the projection.
