how to do a non-linear multi-variate regression
Hello, can I get some input on how to perform a multiple variate regression in Igor? I am using a customized fitting function, non-linear and two to three variables. In the CurveFit panel thought, only X and Y variables are listed, could not find an option for a third variable. Thanks!!
This may be of help:
DisplayHelpTopic "Fitting to a Multivariate Function"
Since the format of a user-defined fitting function requires an input for each independent variable, if you sometimes fit two, and other times three, you will need two fitting functions.
Be sure to use the "FitFunc" function type keyword on your fitting function:
Function threeIndVars(pw, xx, yy, zz) : FitFunc
    WAVE pw
    Variable xx, yy, zz
    etc.
    return ...
