Strange error when calling the function from within function
Jakub
Hello.
I'm experiencing a strange (to me) error.
I have this function (downloaded from the exchange):
#pragma TextEncoding = "UTF-8"
#pragma rtGlobals=3 // Use modern global access method and strict wave access.
// Convert a formatted time string into a number
// of seconds. The function returns -1 if there
// was an error.
Function Time2Secs(timeString)
string timeString
// NOTE: timeString is assumed to be a colon-separated
// string as hours:minutes:seconds PM where
// the PM may also be AM or may be omitted.
// Leading zeros are allowed but not required for each
// of the three digit groups.
// The space between the seconds digits and the
// AM or PM is optional. If neither AM nor PM is
// found, the time will be assumed to already be in
// 24-hour format. The case of AM and PM does not matter.
// The range of the digits is not checked.
Variable hours, minutes, seconds, fract
String ampmStr = ""
sscanf timeString, "%u:%u:%u.%u%s", hours, minutes, seconds,fract, ampmStr
if (V_flag < 3)
print "Error in Time2Secs: could not successfully parse the time."
return -1
elseif (V_flag == 4)
// Determine whether AM or PM or something bogus
// was used.
if (cmpstr(" ", ampmStr[0]) == 0)
// Get rid of the leading space.
ampmStr = ampmStr[1, strlen(ampmStr) - 1]
// Test that ampmStr is now either "AM" or "PM"
// (case insensitive). If not, then it's a bogus string.
ampmStr = UpperStr(ampmStr)
StrSwitch (ampmStr)
Case "AM":
// Compensate for the fact that, eg., 12:30:30 AM is
// only 30 minutes and 30 seconds past midnight (the
// beginning of the day), and not 12 hours 30 minutes
// and 30 seconds.
if (hours == 12)
hours -= 12
break
Case "PM":
// Compensate for the fact that, eg., 12:30:30 PM is
// only 30 minutes and 30 seconds past noon, which
// is 12 hours past midnight (the beginning of the day),
// and not 24 hours 30 minutes and 30 seconds.
if (hours == 12)
// Don't need to do anything.
hours += 12
break
default:
// It's bogus, report error to user.
print "Error in Time2Secs: Could not parse AM/PM string."
return -1
EndSwitch
// Do the conversion into seconds.
seconds += (minutes * 60) + (hours * 60 * 60)
return seconds
// was an error.
string timeString
String ampmStr = ""
if (V_flag < 3)
return -1
// was used.
StrSwitch (ampmStr)
Case "AM":
// and 30 seconds.
if (hours == 12)
hours -= 12
break
Case "PM":
if (hours == 12)
hours += 12
break
default:
return -1
EndSwitch
return seconds
When I'm calling it from within my main function
make/D/O/N=(dimSize(Time_interp_t,0)), Time_interp
Time_interp=Time2Secs(Time_interp_t)
and I'm trying to compile my code, I'm getting this error:
got "Time_interp_t" instead of a string variable or string function name.
(Time_interp_t is a T2d wave with labels and text dates)
When the compiler fails, I cannot run this assignment in the command prompt, getting this error:
unknown/inappropriate name or symbol
However, when I comment out the assignment line in my main function code, compile it, and then run it in the command prompt again, it is executed without any problem.
Why is this happening?
Regards,
JB
How is Time_interp_t defined ?
I guess there is an issue.
However, Igor should throw an "Expected wave name"-error.
HJ
September 26, 2018 at 05:27 am - Permalink
That is a result of duplication of the part of the main data wave to extract only the time values. The main wave is a T2d wave (multiple text and number columns with columns and rows labels).
It's created like this:
Duplicate/O/R=[1,dimSize(wave0,0)][0] wave0, Time_interp_t
The problem is that the wave assignment works in the command prompt but it does not when called from the main function body...
September 26, 2018 at 05:59 am - Permalink
There is no "text and number" in Igor; its either text or number.
You are dealing with text waves. Hence, your duplicate command needs the /T flag.
HJ
September 26, 2018 at 06:38 am - Permalink
In reply to There is no "text <b>and</b>… by HJDrescher
Ok then. Everything is in the text wave with labels (wave0). The numbers in there are also in text format and I need to convert them. So is the time column. But why can I do it in the prompt and not from within the main function body?
September 26, 2018 at 08:08 am - Permalink
Because a function is compiled, it needs to know the type of the Time_interp_t at compile time, when the wave does not yet exist. By using /T with Duplicate, you are telling the compiler that the wave, when it is created, will be a text wave.
This is not a problem from the command line because, when a command is executed, the wave must already exist and Igor can determine the type at that time.
This is explained in the "Type Flags" section of the help for Duplicate and also in the section "Automatic Creation of WAVE References":
DisplayHelpTopic "Automatic Creation of WAVE References"
Another useful topic is:
DisplayHelpTopic "Compile Time Versus Runtime"
I recommend that Igor programmers read the Programming help file (Help->Help Windows->Programming.ihf) and then read it again after you have some experience. As with any programming language, you learn a lot after gaining experience from re-reading the documentation.
September 26, 2018 at 10:30 am - Permalink
In reply to Because a function is… by hrodstein
It was that simple... Thank you very much for pointing that out and showing the help topic!
September 27, 2018 at 02:16 am - Permalink
