Can I start different background tasks depending on if-statement?
Hello.
I have a system which can operate in two different systems: automatic and manual mode.
My goal is to start different background tasks depending on the chosen mode. I can chose the mode with radio buttons and set a global variable (SamplingMethodG) to 1 for automatic or 2 for manual mode. And then with a button I want to start my system. In the function for this button I use an if-statement to check which mode is selected and start the appertaining mode.
My problem is the the background task for the automatic is working. All functions belonging to that task are executed constantly. But if I choose the manual mode it is only executed once.
Do you have an idea why?
Here is the relevant code:
Function RelayInitialize(ctrlName) : ButtonControl String ctrlName Variable defaultRM,instr,status String resourceName = "ASRL8::INSTR" //opens resource manager viOpenDefaultRM(defaultRM) status = viOpenDefaultRM(defaultRM) if (status < 0) ReportVISAError("viOpenDefaultRM", instr, status) endif //opens session with instrument viOpen(defaultRM, resourceName, 0, 0, instr) status = viOpen(defaultRM, resourceName, 0, 0, instr) if (status < 0) viClose(defaultRM) ReportVISAError("viOpen", instr, status) print "Could not open Relay" //return 0 endif //setting attributes for relaycard status =visetattribute(instr,VI_ATTR_TMO_VALUE,50) //Timeout status =visetattribute(instr,VI_ATTR_ASRL_BAUD,9600) //Baudrate status =visetattribute(instr,VI_ATTR_ASRL_DATA_BITS,8) //Data Bits status =visetattribute(instr,VI_ATTR_ASRL_PARITY,VI_ASRL_PAR_NONE) //Parity status =visetattribute(instr,VI_ATTR_ASRL_STOP_BITS,VI_ASRL_STOP_ONE) //Stop Bit status =visetattribute(instr,VI_ATTR_ASRL_FLOW_CNTRL,VI_ASRL_FLOW_NONE) //Flow control for Data Transfer variable/G root:SamplerGlobals:Relaycard = instr Printf "Relay=%d\r", instr //Check which sampling method and start corresponding background task to control relays NVAR SamplingMethodG=root:SamplerGlobals:SamplingMethodG if (SamplingMethodG==1) //automatic sampling CtrlNamedBackground automatic,period=60,proc=AutomaticSampling,start elseif (SamplingMethodG==2) //manual sampling ctrlNamedBackground manual,period=60,proc=ManualSampling,start endif End //Running through all samplers and initialize functions checkcondition and checkformula function ManualSampling(s) STRUCT WMBackgroundStruct &s variable sampler // to check if function is executed once or more print "bla" End //Activates functions to check conditions, formula and if the system should sample and time couting function AutomaticSampling(s) STRUCT WMBackgroundStruct &s //to check if function is executed once or more print "blabla" variable sampler,condition NVAR ParticleSizeG=root:SamplerGlobals:ParticleSizeG if (ParticleSizeG==1) //PM1: sampler 1-4 for(sampler=1;sampler<5;sampler+=1) for(condition=1;condition<5;condition+=1) Checkcondition(sampler,condition) Checkformula(sampler,condition) CheckSampling(sampler) Timecount(sampler) endfor endfor elseif (ParticleSizeG==2) //PM1+PM10: sampler 1-2 for(sampler=1;sampler<3;sampler+=1) for(condition=1;condition<5;condition+=1) checkcondition(sampler,condition) Checkformula(sampler,condition) CheckSampling(sampler) Timecount(sampler) endfor endfor endif return 0 End
Thank you in advance.
I also tried to do a simple version of what I have so far, but now none of the background tasks is working constantly.
September 21, 2018 at 06:33 am - Permalink
In reply to I also tried to do a simple… by neovenecia
I think your background task procedures need return statements.
displayHelpTopic "Background Task Exit Code"
September 21, 2018 at 06:40 am - Permalink
In reply to I think your background task… by tony
Indeed - your task functions need:
See:
DisplayHelpTopic("Background Task Exit Code")
September 21, 2018 at 06:47 am - Permalink
Thank you very much
That was the line I overlooked
September 21, 2018 at 06:55 am - Permalink
