Change Picture resolution
joerg.kunze
Is there any way to change a picture resolution inside Igor? If I use DrawPICT, then it is no problem. But if I access the picture e.g. in a label with
\$PICT$name=MyPict$/PICT$
how can I change the scale or resolution? I tried SetScale, but it seems not to work only on images and not on pictures.
Best regards,
Joerg.
You loaded a picture into Igor's picture store. It has whatever resolution the disk file that you loaded had.
September 17, 2018 at 08:44 am - Permalink
