Accessing a wave from other function which is created inside another function
I had defined a function which creates a wave and then i want to access the wave from another function so that i can compute. I read about wave references but I think it does not satisfy the purpose.
here is the dummy code:
Function createdata() Make /O/T Datawave={{"x1","x2","x3","x4"},{"1","2","3","4"}} End Function LetUsFindAndCompute() String var Variable i for(i=1;i<=4;i+=1) var="x"+num2str(i) //search the element in wave and store the corresponding element and compute to your desires. endfor end
It seems to me wave references do seem to fit your purpose, at least in your example:
Is there something specific which does not work as intended?
September 15, 2018 at 05:26 am - Permalink
well i was passing the wave as parameter to the second function while the first function returned a wave and then tried to duplicate the parameter into a wave which obviously did not work out and threw the error as point return or something i will give the specifics about the error.
the code for the first function was like this
September 15, 2018 at 08:37 am - Permalink
In reply to well i was passing the wave… by coltblaze
[quote=coltblaze]well i was passing the wave as parameter to the second function while the first function returned a wave and then tried to duplicate the parameter into a wave[/quote]
The code that you showed in your original post did not show passing a wave as a parameter.
To get the best answer, it is best to provide a minimal, self-contained example that others can inspect and, if necessary, execute and debug.
Here is an example of a minimal, self-contained example that shows how to pass a text wave from a routine to a subroutine:
September 16, 2018 at 09:31 am - Permalink
In reply to It seems to me wave… by chozo
can we not pass the wave as string reference lets say:
I have a list of waves and i want to create a wave reference in the loop and do some operations.
so this way it is giving error in Waveref=$filename
September 24, 2018 at 01:07 am - Permalink
In reply to can we not pass the wave as… by coltblaze
Untested, but try this:
Note: The wave reference is inside the for-loop, so it is 'refreshed' each cycle. Also, I have added the /T flag to the recordofwaves wave as this is a text wave.
EDIT - changed line in code above from
filename=x[i]to
filename=recordofwaves[i]Hope this helps,
September 24, 2018 at 01:13 am - Permalink
well it is giving the following error :"The wave reference to the Waveref failed "
September 24, 2018 at 03:56 am - Permalink
If you want to store multiple wave references in a wave then you can use a 'wave reference wave', i.e., waves with references to other waves as entries. Then you can skip all this mess with strings. Such waves are generated with
Make/O/WAVE/N=(numofrefs) mywaverefsRead more by executing...
DisplayHelpTopic "Wave Reference Waves"Then you could just do
To fill the indexes with references to all waves in a certain folder you could use something like WaveRefIndexedDFR in a loop. But if you just want to reference all waves just once you could use WaveRefIndexedDFR directly in above for-loop and skip even the stuff with the wave reference wave. Depends on what you want to do exactly (you would have to tell us).
As a side note, I would recommend you refrain from using Igor-own commands as wave names, such as 'x' in this example. Makes debugging much more difficult.
In reply to well it is giving the… by coltblaze
So, you have not supplied a self-contained example reproducing the error.
Here is a cleaned up version that makes the data and illustrates it a working function:
I suspect you are getting the error because you are not managing DataFolders - the waves are in the current datafolder but this is not necessarily the one containing the waves.
September 24, 2018 at 05:40 am - Permalink
