Listbox: Change selection color
I'm using a listbox with colored text.
Function Dostuff()
    Make/T/N=(5,1) tw= "row "+num2str(p)    // 5 row, 1 col text wave (2D)
    Make/B/U/N=(5,1,2) sw       // 5 row, 1 col, 2 plane byte wave
    Make/O/W/U myColors= {{0,0,0},{65535,0,0},{0,65535,0},{0,0,65535},{0,65535,65535}}
    MatrixTranspose myColors    // above was easier to enter as 3 rows, 5 cols
    NewPanel
    ListBox lb,mode=3,listWave= tw,selWave= sw,size={200,100},colorWave=myColors
    sw[][][1]= p            // arbitrary index values into plane 1
    // now, execute the following one at a time and observe the results
    SetDimLabel 2,1,backColors,sw   // define plane 1 as background colors
    SetDimLabel 2,1,foreColors,sw   // redefine plane 1 s foreground colors
    sw[][][%foreColors]= 4-p    // change the color index values
And that text color conveys information.
Now if a user selects row 2 the text color is changed to pink which looks a lot like red. I know that having the colors changed to be properly visible is a good thing in general. But here I would need to have something like a bounding rectangle instead of an all blue for the selection. Or can I change the opacity of the selection blue?
Just checked the Listbox drawing code. We've got some old code in there... At present, we call InvertColor() on the text color for a selected cell.
The selection hilite color is what we are told to use by the OS for a selection. On Macintosh, you can change it in the system preferences. On Windows it's fixed. It would take some work to uncook the drawing code and provide the flexibility you want.
