Using IGOR for fitting data from Labview
SailBlue5
I am running a labview program and every one minute I get new data that I would like to use IGOR to fit to a user defined function and then pass back the needed fitted info back to labview.
My first thought is to use labview to create an igor batch file that Igor will automatically look for and then execute which will fit the data and output another file which labview will read. This seems to be cumbersome.
Is there a better way of doing it?
Thanks
Michael
March 16, 2010 at 08:54 pm - Permalink
March 16, 2010 at 11:27 pm - Permalink
March 17, 2010 at 12:39 am - Permalink
It doesn't do fitting as good as IGOR for the functions I need.
March 17, 2010 at 07:13 am - Permalink
I had a project that required substantial interactive data analysis with measurement data, and opted for the Igor approach, after failing to find a satisfactory LabView method. If you can satisfy the requirements mentioned above, I would urge you to consider Igor for your DAQ needs.
Stephen R. Chinn
March 17, 2010 at 10:28 am - Permalink
