We have code from someone else that was obviously developed on a larger, higher-resolution screen than we are trying to open it on, and half the GUI window is cut off the screen. Is there a way to add scroll bars to the window so we view the whole thing?
But if you are using Igor 7, perhaps you can use these "Panel Size Menus" to make the panel smaller.
http://www.igorexchange.com/node/7966
March 28, 2018 at 09:22 am - Permalink
