How to get window's name
I am writing a function that finds all graphs in an experiments, saves each one to PDF, and then closes (kills) the graphs. I have two questions related to windows.
1. Is there a way to obtain the name of the topwindow? I have a set of graphs with assigned names and I’d like to save each one using the window’s name as the filename. I have used
getWindow kwTopWin, wtitle
to get the window’s title, but in some cases this is not the same as the window's name and I need the name. Is there a command like
getWindow kwTopWin, wname
2. Is there a way to check whether the top window is a graph?
Thanks in advance.
Pietro
HJDrescher
I'd go for the
WinList
command. It returns the names of the windows from front to back.
In order to test whether the topmost window is a graph, you could compare the the first item in the result lists corresponding to all windows and solely to graph windows
•print winlist("*",";","")
vs
•print winlist("*",";","win:1")
HJ
