Save Wave as General Binary
// SaveWaveAsGeneralBinary(pathName, filePath, dataType, byteOrder, w) // Saves the wave's raw data only. This is of use to export to another program. // This works on numeric waves only, not on text waves, DFREF waves, etc. // NOTE: This overwrites the file if it already exists. // Example: // Make/N=128/S jack = sin(x/8) // SaveWaveAsGeneralBinary("", "jack.bin", 0, 0, jack) // This writes 4 bytes per point of single-precision floating point data for a total of 512 bytes. Function SaveWaveAsGeneralBinary(pathName, filePath, dataType, byteOrder, w) String pathName // Name of Igor symbolic path or "" String filePath // Full path, relative path or file name relative to symbolic path Variable dataType // 0 for default; See FBinWrite documentation for other types Variable byteOrder // 0 for default; See FBinWrite documentation for other types Wave w // The wave to save Variable refNum // First get a valid reference to a file. if ((strlen(pathName)==0) || (strlen(filePath)==0)) // Display dialog looking for file. String fileFilters = "Binary File (*.bin):.bin;" Open/D/P=$pathName/F=fileFilters/M="Save wave to file" refNum as filePath filePath = S_fileName // S_fileName is set by Open/D if (strlen(filePath) == 0) // User cancelled? return -1 endif endif Open/P=$pathName refNum as filePath FBinWrite /F=(dataType) /B=(byteOrder) refNum, w Close refNum return 0 End
Ryan
February 26, 2018 at 06:06 am - Permalink
It is helpful to enclose the code in <igor> and </igor> tags for clarity.
February 26, 2018 at 08:45 am - Permalink
Theh waves have been pasted in and are auto named wave0 etc, so I step through them that way.
Any help is appreciated.
February 26, 2018 at 04:11 pm - Permalink
This bit:
is wrong when pathName ="" and filePath is a complete file path; the dialog is invoked when it is not necessary.
I suggest you try this, instead:
February 26, 2018 at 07:56 pm - Permalink
