Changing the bottom axis for waterfall diagram
I have a waterfall diagram, which displays a set of graphs of 'intensity' vs 'theta',
such that the bottom axis represents the unit in theta, θ.
Normally, if I have two waves named 'intensity' and 'theta',
then I can replace 'theta' with another wave called 'vector', Q.
Since Q is related to θ by:
Q = 4*pi/lamba*sin(θ*pi/180)
, then with this command
'vector' = 4*pi/lamba*sin('theta'*pi/180)
, a new graph can be displayed for 'intensity' vs 'vector'.
But as a waterfall diagram is a combination of many waves, so is there a quick way to change the unit of the bottom axis from θ to Q instead of executing the command many times for all the individual waves and re-plot the waterfall again?
Thanks for any help!
ReplaceWave/X trace=intensity, vector
If your waterfall plot is just a graph with lots of traces, use this function:
Note that this function is really basic- it has no error checking, and it replaces the X wave for *all* traces in the graph regardless. It does, however, allow you to use "" as the name of the graph in order to work on the top graph window.
March 8, 2010 at 09:27 am - Permalink
