converting a wave reference into a textwave
I am using the code below to fill a wave with text from a textwave. This type of code works fine for numeric waves, but it does not work with text waves. What am I doing wrong, why w12 does not behave as a textwave?
Many thanks for your input!
Hans
wave/T monstercode, modelT, M_IB_hoog_EC_OK_range
string suffix
string name12=nameOfWave(M_IB_hoog_EC_OK_range); Duplicate/O modelT, $(name12+suffix)/wave=w12
w12[k2]=monstercode[i]
Screen Shot 2018-02-16 at 13.59.04.jpg (19.18 KB)
jtigor
Try adding the /T flag in your Duplicate operation to let Igor know the new wave will be a text wave. See "Type Flags" in the command help for Duplicate for details.
jjweimer
Do you need to say
Duplicate/O/T
? Also, unless you declare it somehow,
suffix
is a null string. The end result that should work is
string suffix, name12
suffix = "_modified"
name12=nameOfWave(M_IB_hoog_EC_OK_range) + suffix
Duplicate/O/T modelT, $(name12)/wave=w12
_sk
In addition to what others have said, I can offer the following example lines you can execute on the command window:
•make/o/t/n=3 w_text0 = {"a", "b", "c"}
•string s_suffix = "_end"
•string s_text1 = nameofwave(w_text0) + s_suffix
•print w_text0
//prints:  w_text0[0]= {"a","b","c"}
•duplicate/o/t w_text0, $s_text1 //creates w_text0_end
•print w_text0_end
//prints:  w_text0_end[0]= {"a","b","c"}
best,
_sk
HansF
Thank you all for your kind help. Adding the /T flag in the Duplicate operation works perfectly indeed!
Hans
