number casting to type
_sk
I needed to cast numbers to specific types (i.e. int16, uint16, etc.) so I wrote the following code, which may be an indication of a bug or an oversight on my behalf. Could you please verify either way?
structure struct_type
char byte
uchar ubyte
int16 int16
uint16 uint16
int32 int
int32 int32
uint32 uint
uint32 uint32
float float
float flt16
double double
double flt32
endstructure
function cast(var, type)
variable var
string type
struct struct_type r
strswitch(type)
case "byte":
r.byte = var; var = r.byte
break
case "ubyte":
r.ubyte = var; var = r.ubyte
break
case "int16":
r.int16 = var; var = r.int16
break
case "uint16":
r.uint16 = var; var = r.uint16
break
case "int":
case "int32":
r.int32 = var; var = r.int32
break
case "uint":
case "uint32":
r.uint32 = var; var = r.uint32
break
case "flt16":
case "float":
r.float = var; var = r.float
break
case "flt32":
case "double":
r.double = var; var = r.double
break
endswitch
return var
char byte
uchar ubyte
int16 int16
uint16 uint16
int32 int
int32 int32
uint32 uint
uint32 uint32
float float
float flt16
double double
double flt32
endstructure
variable var
string type
strswitch(type)
case "byte":
break
case "ubyte":
break
case "int16":
break
case "uint16":
break
case "int":
case "int32":
break
case "uint":
case "uint32":
break
case "flt16":
case "float":
break
case "flt32":
case "double":
break
endswitch
return var
And compare the results of:
•variable a
•a = cast(-5, "uint16"); print a
65531
•a = cast(-5, "uint32"); print a
0
65531
0
I would expect the second call (
) to set variable a
to: 4294967291
, the 2 complement of -5.
matrixop
•matrixop/o result = uint16(-5)
•print result
result[0]= {65531}
•matrixop/o result = uint32(-5)
•print/D result
result[0]= {4294967291}
January 17, 2018 at 01:24 pm - Permalink
Thanks for letting me know about this feature in IP7. It is way more pleasant to the eye like that.
While we are on the topic, does the uint32 struct field also return/ store 0 in the case of -5 in IP7 as well?
best,
_sk
January 18, 2018 at 02:34 am - Permalink
0
January 18, 2018 at 03:26 am - Permalink
