Load & Plot multiple .txt to Common Graph
I'm looking to load and display multiple 2 column .txt files to one graph. So far I've figured out a procedure of my own that easily loads .txt files to a wave using LoadWave and have found another procedure by Drhodstein that does the same in a nicer fashion. However I haven't been able to append these multiple waves to a single graph. It seems this should be an easy thing but I can seem to find a way to make it work primarily because each iteration of LoadWave overwrites the previous.
My code:
Function RamanGraph() Variable refNum, k String message = "Select one or more files" String outputPaths String fileFilters = "Delimited Text (*.txt):.txt;" fileFilters += "All Files:.*;" Open /R/D/F=fileFilters /MULT=1 /M=message refNum outputPaths = S_fileName // Stores the full file names + directories in outputPaths Variable/G numberOfImages = ItemsInList(outputPaths, "\r") // Finds the number of images being opened If(StrLen(outputPaths)==0) Print "User Cancelled" return -1 Endif String columnInfoStr = " " columnInfoStr +="N=Shift;" columnInfoStr +="N=Intensity;" For(k=0;k<NumberOfImages;k+=1) String path = StringFromList(k, outputPaths, "\r") LoadWave/Q/J/D/A/K=0/E=1/W/O path Wave /T imageList // Stores force curve names in ordered list Make /O/T/N=(numberOfImages) imageList imageList[k] = path EndFor End
DrHodstein's Code:
Function LoadOneFile(pathName, filePath) String pathName // Name of Igor symbolic path or "" String filePath // File name, partial path relative to symbolic path, or full path String fileName = ParseFilePath(3, filePath, ":", 0, 0) // Get file name without extension String baseShiftName = "Shift" String baseIntensityName = "Intensity" Variable baseMaxNameLength = max(strlen(baseShiftName),strlen(baseIntensityName)) Variable maxIgorNameLength = 31 // This is to make sure that your wave names don't wind up being too long for Igor to handle Variable clippedFileNameLength = maxIgorNameLength - baseMaxNameLength String clippedFileName = fileName[0,clippedFileNameLength-1] // Print clippedFileName // For debugging only String columnInfoStr = "" columnInfoStr += "N='" + baseShiftName + clippedFileName + "';" columnInfoStr += "N='" + baseIntensityName + clippedFileName + "';" // Print columnInfoStr // For debugging only LoadWave/A/G/D/B=columnInfoStr/K=0/P=$pathName filePath // You may need to tweak this End Function/S LoadFiles() Variable refNum String message = "Select one or more files" String outputPaths String fileFilters = "Data Files (*.txt,*.dat,*.csv):.txt,.dat,.csv;" fileFilters += "All Files:.*;" Open /D /R /MULT=1 /F=fileFilters /M=message refNum outputPaths = S_fileName if (strlen(outputPaths) == 0) Print "Cancelled" else Variable numFilesSelected = ItemsInList(outputPaths, "\r") Variable i for(i=0; i<numFilesSelected; i+=1) String path = StringFromList(i, outputPaths, "\r") Printf "%d: %s\r", i, path LoadOneFile("", path) endfor endif return outputPaths // Will be empty if user canceled End
Any help would be appreciated, I feel that it should be a relatively easy step so save the waves in an iterative manner and then use AppendToGraph to plot them all together.
Garrett
To determine the names of the waves loaded, after LoadWave, execute this:
If the graph already exists, you can then use AppendToGraph.
For another example, execute:
DisplayHelpTopic "Loading Waves Using Igor Procedures"
December 11, 2017 at 01:08 pm - Permalink
December 12, 2017 at 09:00 am - Permalink
