Create a text box that contains a statement or statements, with no input required.
I have this code to create a table with a number of empty waves in it. I want to prompt the user to input their test results. See below
Function BuildDataTable(CtrlName):ButtonControl
String CtrlName
variable pts
Prompt Pts, "Number of Test Points:"
DoPrompt "Enter number of Points", pts
Make/D/O/N=(pts) FlowSet, FlowAct, TimedVol, TimeSecs, VolMeas, VolDry
Edit/N=DataTable Flowset; appendtotable FlowAct; Appendtotable TimedVol; Appendtotable TimeSecs;
END
So after the tables appears I want a window, similar to a "Prompt" window, to say something like "Please enter the test data in the following columns". With a button that will kill the window after its been read. Then the user enters data into each of the waves. DoPrompt wants to have some pulldowns or data entry and that is not needed here. Im sure I just dont know the command name for this. Thanks for the help.
ssmith
jtigor
The operation you are looking for is
DoAlert
By the way, when you include Igor code please enclose the code in <igor> and </igor> tags so that it gets properly syntax-colored.
For example, your code becomes...
 String CtrlName
 variable pts
END
ssmith911
My apologies. I have reread my post and it doesn't clearly stated what I'm trying to do. I want to pause execution of the function after the table is created, then enter in some test values into the table and then continue execution of the function which is supposed to use the entered values and calculate some results. The DoAlert function does not allow me to enter any values into the table.
	String CtrlName
	NVAR G_Pinit, G_PH2O, G_Tcorr
	variable pts
	Edit/N=DataTable   Flowset; appendtotable FlowAct; Appendtotable TimedVol; Appendtotable TimeSecs; Appendtotable VolMeas; Appendtotable VolDry
	DoAlert/T="Data Entry" 0, "Enter the collected data into the table and Press 'OK'"
	Volmeas = (TimedVol/(TimeSecs/60))
	VolDry = VolMeas*(298.15/(273.15+G_Tcorr))*((G_Pinit-G_PH2O)/1013.25)
END
johnweeks
Hmm... I suppose it could be a control panel with "Done" and "Cancel" buttons, and a table as the target window. But I think it might be more natural to use a table subwindow in your control panel.
ssmith911
John, can you elaborate more please. I have zero experience with control panels and pause for user. Please explain the need for a control panel and what it must contain. By simply inserting a PAUSEFORUSER command there is no way to continue. I have attached a screen shot and inserted my code, but I am obviously missing something. After inputting some values into the table ans cannot continue. The table won't close and I have to use windows task manager to close down IGOR.
	String CtrlName
	variable pts
	Pauseforuser DataTable
//	I want to enter values in the table at this point and when execution continues execute the next
//	two lines to complete the table.
END
johnweeks
You can read the detailed description of PauseForUser by executing this command: DisplayHelpTopic "Pause For User"
A control panel is an Igor window with user-programmed GUI. For your application, you need a pretty simple one: a button for "Done", a button for "Cancel" and possibly a TitleBox control with a message to the user.
Your example acts the way it does because PauseForUser prevents interaction with any window other than the table until the table window is killed. But there is no provision for killing the window that is accessible to the user (that is, you). Hence, the need for a control panel that has a button that will either accept the changes or cancel the changes and then kill the main PauseForUser window. Here is a very simple example that illustrates what I was describing:
Function Example()
	Make/O testwave
	Edit/N=PauseTable testwave
	fPausePanel()
	PauseForUser PausePanel, PauseTable
Function AcceptButtonProc(ba) : ButtonControl
	STRUCT WMButtonAction &ba
	switch( ba.eventCode )
		case 2: // mouse up
			// Do something that accepts the new data
			KillWindow PausePanel
			KillWindow PauseTable
			break
	endswitch
Function CancelButtonProc(ba) : ButtonControl
		case 2: // mouse up
			// Do something to discard the results here (kill the wave?)
			break
	endswitch
Function fPausePanel()
	NewPanel/W=(150,50,450,250)/N=PausePanel
	Button AcceptButton,pos={54.00,106.00},size={50.00,20.00},proc=AcceptButtonProc,title="Accept"
	Button CancelButton,pos={175.00,107.00},size={50.00,20.00},proc=CancelButtonProc,title="Cancel"
	TitleBox EditTitleBox,pos={64.00,54.00},size={151.00,19.00},title="Please edit the wave in the table"
EndMacro
Copy that code, paste into the Procedure window, then close the Procedure window. To run the example, execute Example() on Igor's command line. You will see a pair of badly-placed windows (the panel shouldn't really lie on top of the table) that allows you to edit the table or click the buttons in the panel, and nothing else. The action procedures for the panel buttons (AcceptButtonProc() and CancelButtonProc()) kill the windows. The panel is the PauseForUser main window, and when it is killed PauseForUser returns and the function stops executing. Killing the table isn't required, but you indicated that it should be temporary.
ssmith911
John--
Thanks for the example. While walking back from lunch it dawned on me that I could use case statements that are selected via the buttons in a panel to do the different things I want. I was thinking the PauseForUser command had some sort of built in method to pause execution and then resume without much programming and that I was missing it. This example helps a lot.Thanks for taking the time to whip it up for me.
ssmith
ssmith911
John--
IS there a reason that the fPausePanel is described at the end and not in the beginning? Why do you use EndMacro instead of just End at the of the fPausePanel function? Your use of the STRUCT command is something I've never seen as well as the ba.eventcode. If you have time can you explain how these operate. I think I can get this to work with my more rudmentary IGOR skills and CASE statements. Thanks again for the help.
ssmith
hrodstein
It is possible to take a simpler approach. That is to break the task into two steps and require the user to initiate two steps instead of one. Here is an example:
Menu "Macros"
	"Setup/1", DemoSetup()
	"Process/2", DemoProcess()
Function DemoSetup()
	Make/O testWave
	DoWindow/F DemoTable
	if (V_Flag == 0)
		Edit/N=DemoTable testWave
	// This is not necessary if the user knows what he is doing
	DoAlert 0, "Enter data in the table and then choose Macros->Process"
Function DemoProcess()
	Print "DemoProcess: Processing started..."
	// Add your processing here
	Print "DemoProcess: Processing finished"
I prefer the two-step approach for three reasons:
1. PauseForUser is a tricky beast both from the Igor programmer's point of view (i.e., you) and in terms of its internal implementation in Igor
2. The two-step approach is simpler to program and to understand
3. The user is free to do whatever he wants between step 1 and step 2 and can use any tools that Igor provides *
* For example, the user can use the help system, search for text, put cursors on a graph, activate another window to copy and paste into the table, ....... In the PauseForUser method, the user can do only what the PauseForUser panel allows him to do.
johnweeks
ssmith911 wrote: John--
ssmith
The order of the functions is not important.
The EndMacro instead of just End is a bit of sloppiness on my part- I mocked up the panel manually, saved a recreation macro, and then converted the macro into a function. I forgot to change that last line. As you can see, Igor's compiler tolerates that small inconsistency.
ssmith911
So the order of the functions in the procedure window does not matter? So either of these will work? Is that because the compiler loads all of the functions into memory so they can be called at anytime?
//Function order in the procedure
//This will work...
Function One()
	//Lines of code
Function Two()
	//Lines of code
Function CallAll()
	One()
	Two()
//...As well as this?
Function CallAll()
	One()
	Two()
Function One()
	//Lines of code
Function Two()
	//Lines of code
ssmith911
hrodstein--
Thanks for the help. I took your suggestion and user DoAlert at the end of a function to provide info on how to proceed. I am using buttons in a controll panel to execute the functions in the proper order.
	String CtrlName
	setdatafolder root:Packages:Regression
	variable pts
	DoALert 0, "1. Populate the first 4 columns with the test data.\r2. Once data entry is complete press the 'Process Table' button\rPress 'OK' to continue"
END
Function ProcessTable(CtrlName):ButtonControl
String CtrlName
	String fold = Getdatafolder(0)
	Print "%s", fold
	Wave Volmeas, TimedVol, TimeSecs, VolDry, FlowAct
	Make/O/N=(numpnts(VolDry)) xwave, ywave
	NVAR G_Tcorr, G_Pinit, G_PH2O
	Xwave = FlowAct
	Ywave = VolDry
END
JimProuty
ssmith911 wrote: So the order of the functions in the procedure window does not matter? So either of these will work? Is that because the compiler loads all of the functions into memory so they can be called at anytime?
That's right.
But if you put all of the following code into one experiment it wouldn't compile because you have duplicate function names.
But maybe you meant this:
//This will work...
Function One()
	//Lines of code
Function Two()
	//Lines of code
Function CallAll()
	One()
	Two()
...As well as this?
Function CallAll()
	One()
	Two()
Function One()
	//Lines of code
Function Two()
	//Lines of code
