Detecting which subpanel & control was target of interaction
Hi everyone!
With the great help of some of you I have made a panel with different subpanels, all with the same set of controls.
I would now need to know the subpanel the user interacted with upon pressing a button, a checkbox or a popupmenu.
Using the Proc associated with checkboxes, I have been testing several operations to print to the console the results of my tests, but I don't seem to be able to print more than the name of the parent panel, instead of the subpanel.
Could anyone help?
Thanks in advance!
R.
The Panel looks like this:
Function MakePanel()
    NewPanel /W=(0,0,1200,600) /N=MyFunnyPanel/k=1
    //Define Vertical guides
    DefineGuide UGV0={FL,200},UGV1={UGV0,0.33333333,FR},UGV2={UGV0,0.66666666, FR}
    //Define Horizonzal guides
    DefineGuide UGH0={FB,0.5,FT}
    string quote = "\""
    String DataTypeList = quote + "Alpha;Beta;Delta;Gamma;Theta" + quote
    String SectionList = quote + "First;Second;Third;Fourth;" + quote
    //Create subpanels/subwindows where data will be displayed according to user input on controls
    Variable i
    for(i = 0; i < 6; i += 1)
        switch(i)
            case 0:
                NewPanel/FG=(UGV0,FT,UGV1,UGH0)/HOST=MyFunnyPanel
                break
            case 1:
                NewPanel/FG=(UGV1,FT,UGV2,UGH0)/HOST=MyFunnyPanel
                break
            case 2:
                NewPanel/FG=(UGV2,FT,FR,UGH0)/HOST=MyFunnyPanel
                break
            case 3:
                NewPanel/FG=(UGV0,UGH0,UGV1,FB)/HOST=MyFunnyPanel
                break
            case 4:
                NewPanel/FG=(UGV1,UGH0,UGV2,FB)/HOST=MyFunnyPanel
                break
            case 5:
                NewPanel/FG=(UGV2,UGH0,FR,FB)/HOST=MyFunnyPanel
                break
        endswitch
        //Names of Controls
        String SelectData = "SelectData"+num2str(i)
        String Selectsection = "SelectSection"+num2str(i)
        String CheckTS = "CheckTS"+num2str(i)
        String CheckHist = "CheckHist"+num2str(i)
        String CheckBar = "CheckBar"+num2str(i)
        String PopButton = "PopButton"+num2str(i)
        //Indicate controls needed
        PopupMenu $SelectData, title="Data Type", bodyWidth=110, value=#DataTypeList, pos={120,10}
        PopupMenu $SelectSection, title="Section", bodyWidth=100, value=#SectionList, pos={270,10}
        CheckBox $CheckTS,pos={5,30},size={75,15},title="Time Series",value=1,mode=1, proc=CheckPlotTypeProc
        CheckBox $CheckHist,pos={95,30},size={75,15},title="Histogram",value=0,mode=1, proc=CheckPlotTypeProc
        CheckBox $CheckBar,pos={185,30},size={75,15},title="Average",value=0,mode=1, proc=CheckPlotTypeProc
        Button $PopButton,title="pop",size={30,20}, pos={280,30}
        // add more controls here...
        RenameWindow #,$("P" + num2istr(i)) //Each subwindow has a name
    SetActiveSubwindow ## //Go back to parent window
    String/G ListOFSubWindows = ChildWindowList("MYFunnyPanel")
The controls are on sub panels so they do not need unique names (only unique within each sub panel).
As an example, see below:
    NewPanel /W=(0,0,1200,600) /N=MyFunnyPanel//k=1
    string quote = "\""
    String sSubPanelName
    Variable i
        switch(i)
            case 0:
                break
            case 1:
                break
            case 2:
                break
            case 3:
                break
            case 4:
                break
            case 5:
                break
        endswitch
        sSubPanelName = "P" + num2istr(i)
        RenameWindow #,$sSubPanelName //Each subwindow has a name
        //Names of Controls
        PopupMenu SelectData, title="Data Type", bodyWidth=110, value=#DataTypeList, pos={120,10}
        PopupMenu SelectSection, title="Section", bodyWidth=100, value=#SectionList, pos={270,10}
        CheckBox CheckTS,pos={5,30},size={75,15},title="Time Series",value=1,mode=1, proc=CheckPlotTypeProc
        CheckBox CheckHist,pos={95,30},size={75,15},title="Histogram",value=0,mode=1, proc=CheckPlotTypeProc
        CheckBox CheckBar,pos={185,30},size={75,15},title="Average",value=0,mode=1, proc=CheckPlotTypeProc
        Button PopButton,title="pop",size={30,20}, pos={280,30}, proc=MyPopButtonProc
Function MyPopButtonProc(B_Struct) : ButtonControl
    STRUCT WMButtonAction &B_Struct
    if(B_Struct.eventCode != 2) // ignore everything except mouse up
    String sWin = B_Struct.win
    String sSubPanelNumber
    SplitString/E=("#P([[:digit:]]+)") sWin, sSubPanelNumber
    Variable vSubPanelNumber = str2num(sSubPanelNumber)
    String sSelectDataValue, sSelectSectionValue
    ControlInfo /W=$sWin SelectData
    sSelectDataValue    = S_Value
    ControlInfo /W=$sWin SelectSection
    sSelectSectionValue = S_Value
    printf "Panel = %g, DataValue = %s, SectionValue = %s\r", vSubPanelNumber, sSelectDataValue, sSelectSectionValue
Hope this helps,
Kurt
Sorry John, could you please expand that a bit further?
From DisplayHelpTopic "WMButtonAction" i saw this: "char win[MAX_WIN_PATH+1] // Host window or subwindow name" sort of matching what you say but I have no idea of what to do with it.
I guess that I could use a swich-case-endswich approach combined with eventcode numbering (Case 2) to detect mouse click on control, but how do I go from that to extracting the subwindow name and control name is not entirely clear to me.
Thanks for the help!
Kurt, many thanks for this - I guess we were posting almost at the same time.
I'll have a look. As you can see your previous example for the overall panel design was very helpful.
Many thanks again!
Cheers,
R.
It looks like you are already doing it:
So maybe I misunderstood what the present problem is. In my testing, bstruc.win contains the full subwindow path to the subwindow that owns the button that triggered your action proc.
Thank you John. I needed a bit of studying, all is more clear now.
Cheers,
R.
