IgorPro 7 error with hdf file ?
millot1
I am trying old codes on 7.
No issues with HDF5 files handling so far.
But when I try to open and HDF file with a code (see below) that previously worked on 6.37, the code stops and i get the following in the command window
"Missing text resource for error: -111 ".
macro BasicHDFLoader()
SetDataFolder Root:
HDFInfo SDSInfo
String S_file=S_fileName
HDFReadSDS Ref=-2, S_file // Reference
duplicate/o HDF_SDS_Wave wave1
NewImage wave1
HDFReadSDS Ref=-1, S_file // Shot
duplicate/o HDF_SDS_Wave wave2
NewImage wave2
SetDataFolder Root:
HDFInfo SDSInfo
NewImage wave1
NewImage wave2
Any obvious mistake here ?
Many thanks
August 25, 2016 at 11:24 am - Permalink
Many thanks
August 25, 2016 at 11:29 am - Permalink
Thanks for the quick turnaround.
I am trying to load a file with two images
HDF_SDS_NumSets==1
I just tested this and it worked fine for the first image in my HDF file... but not for the other image in my file: only wave 1 was created and displayed as an image, then it crashed and I got the followong error message this time Missing text resource for error: -109
August 26, 2016 at 08:32 am - Permalink
First, please make sure that the only HDF XOP that is activated is the one I attached to this topic last night. Check both Igor Extensions folders. Execute this for details about the two Igor Extensions folders:
DisplayHelpTopic "Special Folders"
If it crashes with the latest HDF XOP, please send a file and a command that I can use to reproduce the crash to WaveMetrics support. Choose Help->Contact Support to start your email as this will include information about your system that may be useful.
August 26, 2016 at 10:52 am - Permalink
The fixed XOP is attached.
As noted, this is for Igor7 and Macintosh 32-bit only.
August 26, 2016 at 03:37 pm - Permalink
October 13, 2017 at 04:19 pm - Permalink
Possible - yes, but it is unlikely to rise to the top of our to do list.
It is possible to compile a 64-bit version of the HDF4 library according to https://support.hdfgroup.org/release4/obtain.html.
However, our HDF4 code was written before 64 bits was on the horizon and so would require considerable modification. And I have not seen much demand.
There is an h4toh5 command line tool. Executables are supposed to be available at https://support.hdfgroup.org/products/hdf5_tools/h4toh5/download.html. However, the Macintosh download is a ".dms" file and I don't have software that decompresses .dms.
It is possible to build your own using source code available at the same page but I suspect that it is involved as you first have to build the HDF4 and HDF5 libraries separately plus optionally the HDF-EOS2 library.
October 13, 2017 at 05:47 pm - Permalink
See http://www.igorexchange.com/node/8035
October 28, 2017 at 05:35 pm - Permalink
Thanks
October 30, 2017 at 09:33 am - Permalink
