I'm using Igor to control Agilent DC power supply and I can write data to device but I can't read the data from it .Thus , do I need to install NIDAQ tool.
This question was also sent to WaveMetrics tech support. My answer was:
No, NIDAQ Tools MX won't help with that problem. Do you know how the power supply is controlled? It is likely through a serial port or USB port, using either our VDT XOP or the VISA XOP. To read data will require learning the commands to send to the power supply to tell it to send data, and then reading the data with the appropriate VDT or VISA function calls.
It's quite possible that another customer has already solved this problem- you may wish to check out IgorExchange.com to ask about it.
It now seems that SATTAM is using GPIB to communicate with the power supply. In that case, you must be using the NIGPIB XOP to control the power supply. My answer is still the same: To read data will require learning the commands to send to the power supply to tell it to send data, and then reading the data with the appropriate VDT or VISA function calls.
Hopefully someone reading this thread can give you some help.
Does that mean that you don't know how to write the NIGPIB XOP commands to read data, or that you have tried sending commands to the power supply and got no response, or that there was a problem with the NIGPIB reading commands? At this point, we need more details of what you tried and what the result was.
October 9, 2017 at 03:32 pm - Permalink
NIDAQ would be an option in case you measure the outputs via an NI6008 (or similar). But seriously, that should be a last resort solution.
HJ
October 10, 2017 at 02:31 am - Permalink
Thanks
October 10, 2017 at 03:22 am - Permalink
Does writing work from Igor?
Can you read values using the original software?
October 10, 2017 at 08:32 am - Permalink
October 10, 2017 at 09:15 am - Permalink
October 10, 2017 at 09:40 am - Permalink
Wishing you the best
Sattam
October 13, 2017 at 04:24 am - Permalink
