pxp default application (macOS)
sjr51
I am using Igor 7.05 on macOS 10.12.6. Since the update to 7.05 (I think), opening a pxp by double-click in Finder has defaulted to the 32-bit Igor application. Changing it via right-click, alt, "Always Open With" or Get Info to Igor64.app doesn't hold the preference. If Igor64 is open, double click opens the pxp in Igor64. Very weird. Not had this problem previously. I'm guessing the problem is on my mac. Anyone else had this issue? Ideas to resolve?
I had the same issue. Same experience, changing the preferred application would not stick. My very crude fix was to delete the 32 bit version of IP7.
October 3, 2017 at 07:32 am - Permalink
October 4, 2017 at 12:19 am - Permalink
