Built-in Graph Pop-Up Menu
gregorK
Is there any way to get the information which built-in Graph Pop-Up Menu Item was selected by the user?
I can catch a modified event with a window hook (I am interested in catching trace append/remove, color change events), but I have no idea how to understand which of the menu items was chosen since it is a built-in menu ... (with a user menu one can call GetLastUserMenuInfo) ... I am on IGOR 6.37
Thanks for any help!
Gregor
DisplayHelpTopic "IgorMenuHook"
Pay close attention to the value of the isSelection parameter.
September 8, 2017 at 09:59 am - Permalink
Gregor
Gregor K
ALOISA Beamline
Elettra Synchrotron
September 8, 2017 at 02:13 pm - Permalink
Following your reply I have just checked the
IgorMenuHook
function, but it seems that it does not get triggered when using built-in Pop-Up Menus (eg. Right-Click on a Graph), at least not on my version of Igor (6.37). Is this true or am I doing something wrong?Is there any other way to trigger on a user selected menu item of a built-in Pop-up Menu?
Thanks again for your help.
Gregor K
ALOISA Beamline
Elettra Synchrotron
September 11, 2017 at 01:02 am - Permalink
I skipped over the bit about you using the popup menus instead of the menubar menus.
The feature you want isn't implemented in Igor (any version).
The idea of the menu hook is to give the programmer an opportunity to modify and respond to menubar menu items.
Relatively few people have used the feature, and so it was never extended to contextual menus such as are in the graph.
Even the existing hook function really isn't designed to capture whether the user completed using the task that the menu item implements.
For example, the hook can tell you that the user selected the Graph->Modify Trace Appearance dialog, but doesn't tell you whether the dialog was cancelled or not.
I think you'll need to approach your problem from a different direction.
Why not use the graph's "modified" event in your own window function and compare the trace characteristics before the menu pops up (you can catch that event; see the examples) with the characteristics when the modified event comes in?
September 11, 2017 at 11:25 am - Permalink
Macro DemoHandlingGraphChanges()
Make/O data1=x
Display/K=1 data1
setwindow kwTopWin hook(changeHook)= BeforeAndAfterHook
Function BeforeAndAfterHook(s)
STRUCT WMWinHookStruct &s
strswitch(s.eventName)
case "modified":
HandleGraphModified()
break
endswitch
Menu "GraphPopup", dynamic
RememberGraphSettings(), /Q, Beep
Function/S RememberGraphSettings()
String/G root:recreationBefore = WinRecreation("",4)
return "" // menu item disappears
Function HandleGraphModified()
SVAR/Z before= root:recreationBefore
String after = WinRecreation("",4)
if( CmpStr(before,after) != 0 )
// To Do:
// Check for differences, and do what' needed
Print "--- before-- "
Print before
Print "--- after-- "
Print after
September 11, 2017 at 02:13 pm - Permalink
Gregor K
ALOISA Beamline
Elettra Synchrotron
September 11, 2017 at 05:50 pm - Permalink
Add this request to the wish list for relatively few people + 1. I would like to be able to be able to override the context menu on graph windows to the fullest extent so that I can build my own list of context options.
Alternatively, if easier at least for the moment, I wish that I could put my choices as the FIRST set of items in the context menu rather than the last set in the (long) list of default options.
Also, the default context menu seems to know whether the user is selecting a trace or not. However, the TracePopup menu option is active even when a user selects a region that does not have a trace.
The immediate use case is to allow users to have a context menu to delete points in a wave trace that is being used on an image as selection markers for background locations.
February 13, 2021 at 09:00 am - Permalink
Make that +2. For my use case, I'd like to add some controls to a graph when the user clicks an item in the context menu.
March 17, 2021 at 10:21 pm - Permalink
